Thanks Thanks:  2
Likes Likes:  6
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Teryx4 audio upgrade
    I've been wanting to add a subwoofer & upgrade my amp for awhile now. I decided to attempt a custom fiberglass enclosure and failed miserably. It wasn't large enough (sounded like crap) and reduced passenger floor space. So I decided to build a roof mount enclosure and damn it sounds awesome !!!!! While everything was tore apart I added a fuse block, 2-way radio and relocated the amp to the trunk. Soon I'll be adding a second battery.
    Using Tapatalk
  2. Thanks WV Hot Rod Rhino thanked for this post
    Likes Timmi, WV Hot Rod Rhino liked this post
    madmax 1's Avatar
    frostburg md
    4,019
    nice work
    Thanks... Lots of time and some trial & error but the outcome was worth it !!!
    Using Tapatalk
    Clayton, Mi
    3,256
    Nice project.
    Sweet
    Quote Originally Posted by chilly2031 View Post
    Sweet
    Once you hear it chilly you'll want one !!!
    Using Tapatalk
  8. #7
    he be bumping thru da woods now.......
  9. #8
    Smoked my cheap $100 MB Quartz back in July. Thanks to James I now have this awesome 600w 5ch Rockford amp !!!! I finally got around to tuning the amp and removed all the poly fill from my sub enclosure. Now it BOOMS better than it ever has !!!!!!
  10. Likes Snorider, WV Hot Rod Rhino liked this post
  11. #9
    With my current amp able to run a 2ohm load I decided to try out this 10" 300wRMS 4ohm DVC MB Quart I had laying around. I purchased the 4ohm SVC Rockford because my old amp wouldn't handle running a sub at 2ohms. WOW, is all I can say !!! I should have done this 6months ago. The bass is clean and hits harder than before !!!!
  12. Thanks WV Hot Rod Rhino thanked for this post
    Likes WV Hot Rod Rhino, madmax 1 liked this post
  13. #10
