Better hop to it James.....i would say the natives will scalp your head if you don't post up soon but that's not a good enough trophy. They may scalp you ass crack though...that seems to be what everyone talks about the most lol. Good to hear it's an awesome machine. Looking forward to hearing a full review. I thing a drag race is in order!
2006 Rhino 660
686 Big bore, 11:1 comp, stage 1 cam
Elka stage 3 shocks
Power steering
Innovate AF gauge
Temp,Volt, and Fuel gauges
12" ITP beadlock wheels
26" ITP Terracross tires
Trail bright LED headlights
Trail bright 30" LED light bar
RZR seats with flat aluminum bases & 4 point harnesses
Dual battery set up with battery separator and 8 place fuse block
ask away!!!...suspension is awesome!!!
How is the power on the thing? Comparable to a 686 or what???
2006 Rhino 660
Elka stage 3 shocks
Power steering
Innovate AF gauge
Will it out run yours? What do you think top end will be with some minor work (cam,cdi,and so on)?
2006 Rhino 660
Elka stage 3 shocks
Power steering
Innovate AF gauge
Vendor
What's the top speed from factory?I've seen all kinds of numbers.Not sure what to believe.
08 Resurrected Rhino build and your custom SXS fabrication shop @ Baxter Built Fabrications. Give me a call at 419-953-8509 if you have any questions.
steep hills was 22-24mph in high but dont take that the wrong way it was steep...hoping to gain 20mph on same hill with sheave...i will make vids on this...my rhino with stroker on same hill would do 54-56..level was 53 and 54 every now and then on the wolverine.....gonna make small adjustments on shocks....3 turns on preload and 2 clicks harder on high speed compression and 3-4 harder on low speed compression and it should be ready to hit anything...had a little to much sway for me to lay it in the corner at 50 but still not bad at all
all in all are you happy with it ?
WV Hot Rod Rhino
gotta get nikki to type the review....some stuff we have to make before we discuss cause there is companys copying what we do for some reason...lol
I done told you what I think about patents, I ain't sayin' no more
Timmi
X2 I agree but when I said the same thang to him his reasoning for not doing it made a hole lot of since. A moms and pops company expecially one that likes to cut his customers brakes on pricing it is very difficult to get a patent because of pricing maybe that's why there prices are mostly higher then his. I'm just glad to here I can still smoke him lol.
JBS 787, bored throttle body , +1ported head, JBS deshrowded valves,kibble white valve springs, muzzy exshaust,dynatek coil,TCP oil cooler, triple pass radiator,billit one steering rack,heavy duty steering tierods, heim joints,+6 long travel,tilt wheel, radius roll cage, JBS rear splash shield
Bead lock wheels , bear claw tires , power steering
My Jagged X 900 spanked his ass all weekend.
