Thanks Thanks:  4
Likes Likes:  16
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
    rodneygt's Avatar
    Summit, MS
    1,131
    Good idea. Thanks. Yes my rectifier is in its stock location. From your pic, it looks like it probably would work. It's a little hard to tell whether the electric motor part would tilt back into my hoses. I took a pic from above to show how much the hoses stick out. And I rotated the other picture from yesterday so you can see it better.
    madmax 1's Avatar
    frostburg md
    4,019
    it looks like it would be really close to the hoses you may have to do some rerouting I had installed my painless wiring fuse block right were the motor goes so I had to move it over but it worked out, the price James is selling these for is a lot less than the super atv site
  3. Likes Kenny G liked this post
  4. #13
    Quote Originally Posted by madmax 1 View Post
    also Rod if you go to the super atv web site and look at them you can download the pdf instructions and check them out
    Mick, Thanks for your pic, I went to super atv site on my tablet last night and looked at instructions but not very clear. Your pic is worth a 1000 words. You got my mouth watering,lol.
  5. #14
    madmax 1's Avatar
    frostburg md
    4,019
    I don't know why I held off as long as I did , I guess I didn't think it would make the difference that it did AWESOME if you need any more pics or info let me know
  6. Thanks jimclemjr thanked for this post
  7. #15
    Arkansas
    115
    This is on my to do list. Probably before summer is over.
    Benchmark built 720 Stroker (2007 Camo 660) - JE 102mm Pro Series 10:1 Piston, +4 Stroker Crank, Ported & Polished Head, Kibblewhite +1 Valves, Kibblewhite Valve Springs, Raptor Stage II Cam, billet middle drive plate, JBS HotRod Sheave, 14gr OD weights, Orange Spring, weighted Airdam clutch shoes, Dynatek CDI & Hot Coil, Muzzy Dual Exhaust, FCR41 Carb, 700 Cam Tensioner, Mishimoto Radiator with TCP Shroud and Spal Fan, Alba Fuel Pump, 27.5" Pitbull Rockers, EZ Steer and Snorkels
  8. #16
    Brian lee Rhino450's Avatar
    Tuscola Texas
    1,742
    super atv power steering
    does anyone run this kit with tilt steering. on mine its great in the 2 upper pisitions like stock, and when i tilt the wheel down or way down the ps is non existiant. just wondered if anyone runs this setup and it works with the wheel tilted down
  9. Likes Kenny G liked this post
  10. #17
    CA Redneck ASPENDELLROVER's Avatar
    Coyote Flats
    2,552
    teddy does
    Sent from my momma's basement
    "The family Comfort Wagon"..JBS sheave, +6 LT w/kings, 4 seat cage w/3 twisted stitch seats
  11. #18
    T.Rhino's Avatar
    Kenova W.V
    2,784
    I have never tried it in anything other then the lowest posistion but I will have to say it doesn't work as good as my old power steering unit. Don't get me wrong it's definitely better then stock but not one finger easy like the old unit was, I will have to cheak that out and let you know.
    JBS 787, bored throttle body , +1ported head, JBS deshrowded valves,kibble white valve springs, muzzy exshaust,dynatek coil,TCP oil cooler, triple pass radiator,billit one steering rack,heavy duty steering tierods, heim joints,+6 long travel,tilt wheel, radius roll cage, JBS rear splash shield
    Bead lock wheels , bear claw tires , power steering
  12. #19
    Tuscola Texas
    1,742
    mine has 4 positions when im in top 2 positions feels like my wifes rzrS that has powersteering. when im in bottom 2 feels like stock but stiffer cause i have 2" wheel spacers up front. just wanted to check with someone else. i have 2 different troubleshooting guides from super atv. gonna have to check the readings when im in the lower 2 positions cause i havent done that yet. top 2 positions all readings r within limits
  13. #20
    scottwv's Avatar
    Charleston , WV
    2,193
    Quote Originally Posted by T.Rhino View Post
    Can you see over the wheel if it's not on the lowest setting ??
  14. Likes Kenny G, madmax 1 liked this post
