Green shag to match the rhino
After washing the Rhineaux, I use furniture polish on all surfaces. Shines and makes it easier to clean the next time.
I get the cheap stuff from any dollar store.
Sent from Florida, wishing I were riding in WV!!
2012 700SE JBS HotRod Sheave with 16g weights, greased~~Raptor Stage 1 Cam~~Dynatek CDI~~Bazzaz ZFi fuel controller~~Rigid HID Hi/Lo Headlights~~10" Trail Bright LED light bar~~26" Maxxis BigHorn Tires on 14" MSA M20 Black Kore wheels~~CFM 2" Lift~~JET SXS Products aluminum front and rear skid plates~~JBS Radiator splash shields and rear splash shield~~4500# Venom winch/synthetic cable~~3 gauge panel w/ switches~~RZR seats~~
CLR will bring of stain off without taking the coating off of the bolts
We can just make this a sticky and you can add to it.
swapping the fuel hoses is another good one. so the filter sits ontop of the tank instead of its original position. helps to stop tearing up ur fingers tryin to change the filter
sent thru smoke signals directly out the top of my teepee!!!
Follow me on Instagram @rdavis512
For updates on the build and other randomness
Old No.7
2015 camo Viking eps
JBS extreme clutch with secret rainbow spring
16" msa throttle wheels wrapped in 35" terms
50" light bar with strobes
Teryx shocks
superatv 4" portals
Strong made lift(3")
Chopped cage 3"
Boss blue tooth amp with 2 4"pods And 2 6" pods
Half windshield
Old no7 build thread
http://hotrodforums.net/forums/showt...?3501-Old-No-7
Done!
Glad you started this post,I have been thinking about all day and here it is thanks Teddy.
2008 700 sport, JBS sheave OD weights,purple spring,MSD,floor guards,sat radio,RydeOn cover,Aluminum stick guards,JBS radiator guards,JBS skid rear,30`and 10`
Trailbright LED`s,K&N,rear window,2`lift,RZR seats...
http://hotrodforums.net/forums/image...ine=1422123669tons of other stuff...
What do think about carrying spray bottle of Rain X washer fluid with you on a ride to clean your windshield.
