Results 1 to 2 of 2
    10,102
    Polaris RZR XP Turbo Manual Coolant Fan Override Switch Kit
    This manual fan override switch from XTC Power Products allows you to keep the factory electric coolant fan on after the factory thermostat has shut it off.
    The kit is plug and play using Weather Pack connectors and our adapter uses a sealed Weather Pack relay system with Diode Protection, other companies just use non sealed relay that cannot take mud and water. Also included is a Carling sealed Red LED Rocker switch.
    To install unplug the factory fan connector and plug our adapter in the middle and re plug in. Using the supplied self tapping screw attach the relay to the fire wall. Run the fused main line to Positive Battery power, Install the switch in the dash.
    The stock computer controlled fan function remains functional.
    Features:
    • Fits 2016 RZR XP Turbo
    • Easy Install Plug and Play
    • Uses Weather Pack Connectors and Weather Pack sealed relay mount
    • 40 AMP Sealed Relay with Diode Protection
    • Carling Sealed Rocker Switch with Red LED
    Direct link: Polaris RZR XP Turbo Manual Coolant Fan Override Switch Kit
    Clayton, Mi
    3,256
    Nice looking product.
