Mud-ring
Help : Front wheel bearing play
I just changed one of my front wheel bearings on my '08 700 rhino with parts from JBS (thanks James).
Did everything according to the JBS video.
I put it all back together and still have a very small amount of play, basically the same as before the new bearing.
Is this normal ???
Also I checked the other side and it has less play, but I can still notice it when I try to move the wheel.
2008 Rhino 700
Midnight Edition,
Uni air filter,
Machined sheave (not sure who did it),
HID headlights,
No windshield and loving it !!
Moderator
Sure it's not A arm bushings? I did the same thing on my teryx. Idk about rhinos though
Mud-ring
The A arm bushings are fudging, but if I put my fingers on the rotor and spindle I can feel it slightly move.
Since we're on the subject is it ok to have some play in the A arm bushings ?
2008 Rhino 700
Midnight Edition,
Uni air filter,
HID headlights,
Mud-ring
The A arms do have some play and this is a part of the overall play at this wheel(is this normal ?)
While I'm touching brake rotor and spindle at the same time and jiggle the wheel I can feel slight movement.
This tells me it's something else
2008 Rhino 700
Midnight Edition,
Uni air filter,
HID headlights,
Moderator
oilcan1001
Once I put garage products in mine I have none at all.
Moderator
oilcan1001
Ball joints maybe
^^^...x2 ...check your tie rods too. I have never seen a-arm bushings "wear" out on a rhino.
I had the same issue on my pass side . I could put new Yamaha bearings in , and still have a little play...ended up the spindle being bad.
It ends up being the spindle. I've had to replace both to get rid of it completely. Just replaced all 4 and still have some play. I just wait till it gets excessive then replace spindle and all!
06 Rhino 686 s/e blue, 11:1 piston, stage 1 hot cam, raptor springs, JBS sheave and clutching, cmf 2" lift, alum air box, exhaust tip, dial a jet, j strong roof, ride on dust shield, power steering, Stage 5 Elka's riding on 28" 11 14 mega mayhems all around on sti hd3 wheels, hp cooling fan, 3500# winch, 32" led light bar and stuff!
Mud-ring
Correction, I meant A arm 'ball joints' have some play
2008 Rhino 700
Midnight Edition,
Uni air filter,
HID headlights,
