Likes Likes:  1
Results 1 to 4 of 4
    Oct 2016
    Western Iowa and Northern MN in the summer
    27
    Low vs high range question
    I don't see a lot of difference between low and high range. I can reach 41 mph in low range which is only about 10 mph less than high range. Is this normal? Other machines that I have owned had a much more noticeable difference in gearing between the ranges.
    2016 Viking EPS
    Yamaha folding windshield
    Yamaha soft rear window
    Sedona Rip Saw R/T 27x9-14 front, 27x11x14 rear
    Sedona Raceline Mamba alloy wheels
    Moto Alliance 3500 lb Viper Max winch
    Eagle snow plow with 72" blade
    JBS Extreme Sheave w/17g OD weights
    Slugged wet clutch
    Purple Eibach secondary spring
    10,102
    Gear ratio 2.554–0.705 : 1
    Low range 31/16 (1.938)
    High range 30/21 (1.429)
    Reverse gear 23/14 × 28/23 (2.000)
    not a lot of difference
  3. Thanks WV Hot Rod Rhino thanked for this post
    Likes WV Hot Rod Rhino liked this post
    Oct 2016
    27
    Thanks Timmi!
    2016 Viking EPS
    Slugged wet clutch
    10,102
    I don't know if Wolverine is different but my low range feels a lot lower than high.
