Secondary sheave/wet clutch drum
For the life of me i cannot get the secondary spring nut to crack and I'm even using a spring compressor. It appears the spring collar is bent now too. Anyone had this issue before?
Also, when do you guys recommend it is necessary for a new wet clutch drum?
Thanks in advance
It's compressed all the way when the nut is tight.,your just holding it to keep it from flying apart when the nut comes off
WV Hot Rod Rhino
Thanks James yeah but this nut is seized on here i can not get it off to service this secondary
You will wanna get a new washer...we have them
Put nut in vice and spin sheave to beak loose then put back in spring compressor to take apart
Thanks James got er off new grease in secondary. Binds when traveling up and down now must've been why I had to force it so much to get the nut off.
Thing should move freely no? I will be calling you to order one looks like lol. How long to get one to Alberta Canada?
Post Thanks / Like - 2 Thanks, 2 Likes, 0 Dislikes
SteveS
I got er Steve.
However it doesn't seem like my secondary moves freely. Wants to stop before maxing out on the pins. Should it not move all the way up and down on those pins?
Schatz
I got er Steve.
With the nut, collar (washer) and spring off, you should be able to slide the moveable sheave off. There will be the pins to remove. Clean and grease everything and then re-assemble. Sand and dust could be gumming up the works. The service manual should be helpful regarding the details.
