Results 1 to 3 of 3
    10,107
    Kawasaki teryx 4 dual compartment cooler/cargo box
    JBS is a SATV dealer
    Kawasaki Teryx 4 Dual Compartment Cooler/Cargo Box
    Who doesn’t need more storage for your drinks and tools on your Kawasaki Teryx 4? You need SuperATV’s dual compartment cooler/cargo box. This cooler/cargo box has been designed specifically for the Teryx so it fits perfectly in the bed to maximize storage space and insulation while maintaining a sleek, low profile.
    The SuperATV Difference
    At SuperATV, we don’t believe in settling for good enough. We could compromise cargo space and utility with a bulky, one-size-fits-all cooler that we bungeed to the bed, or we could design a sleek, custom fitting, cooler that bolts securely to the bed utilizing factory mounting points and boasts a massive 67 quarts of storage capacity.
    Cold and Convenient
    When we designed this cooler, we wanted it to feel like a luxury item and premium cooler all in one. That’s why it’s made with top-of-the-line insulation up to 3.5” thick that’s packed between layers of linear-low-density polyethylene to keep your drinks cool and includes drain plugs in the bottom of each compartment so you can unplug them and forget about it when you’re done for the day. The top latches securely with high strength rubber latches and opens easily with the use of 2 gas struts. We built this cooler/cargo box with dual storage compartments so you can store both your dry items and your drinks without worrying about everything getting soaked even if you roll it! It’s a cooler built by riders, for riders.
    FEATURES
    • Up to 3.5″ of foam
    • 67 Quarts of storage capacity
    • Sleek low-profile design
    • Designed specifically for the Teryx cargo bed
    • State-of-the-art insulating foam
    • Made with LLDPE
    • Dual cargo spaces so you can carry tools and drinks together
    • Each cargo space measures 10.75″ x 19.33″ x 9.0″
    Nice
    I want one
    Sent from my SM-G920P using Tapatalk
