Results 1 to 9 of 9
Thread: Crate motor
    Crate motor
    Who’s got a Viking motor kickin around from a build that is just taking up space. Dreaded middle drive put a crack in my case.
    Exploring options. Yamaha reliability tried and true quality.
    ryanO's Avatar
    Mt hope
    1,631
    Damn it man that sucks! It almost got mine too but we caught it just in time. You got pics of the crack?
    Follow me on Instagram @rdavis512
    For updates on the build and other randomness
    Old No.7
    2015 camo Viking eps
    JBS extreme clutch with secret rainbow spring
    16" msa throttle wheels wrapped in 35" terms
    50" light bar with strobes
    Teryx shocks
    superatv 4" portals
    Strong made lift(3")
    Chopped cage 3"
    Boss blue tooth amp with 2 4"pods And 2 6" pods
    Half windshield
    Old no7 build thread
    http://hotrodforums.net/forums/showt...?3501-Old-No-7
    Yamaha should have corrected that problem as long as the 686 has been in production
    buckg2's Avatar
    Mar 2015
    Howard, PA
    161
    It almost got mine too. Noticed a noise and spedo not working on de-acceleration.
  5. #5
    Glad I rebuilt mine before it happened to me too. Was always playing in the back of my mind. Where and when? Sad to hear of your troubles. Cheers
  6. #6
    Is this a problem with all years of the Viking? Got a 2015 and thought there was mention of it having been addressed for that model year and on.
    Following that, does somebody have a link to a page with instructions on how to check for and fix?
  7. #7
    ryanO's Avatar
    Mt hope
    1,631
    Yes mine is a 15 and had backed out when we tore my motor down. You can check them if you pull the output yoke but you have to split the cases to fix it. One way to see if it’s going out is to look at the bottom of your motor where the cases meet and see if there is oil seeping out
    Old No.7
    Teryx shocks
    superatv 4" portals
    Chopped cage 3"
    Half windshield
  8. #8
    I can’t fathom how common this is.
    So basically when someone buys a new Viking they should be justified in having the dealer pull the motor and split the cases.
    Should definitely spread the awareness here as Yamaha is touted as a true and reliable manufacturer.
    I can assure you I didn’t buy a Viking for its power plant and would have considered other options if I’d known otherwise!
  9. #9
    it just doesn't happen to each and every engine but it should have been corrected I agree. many people go thousands of miles with no issues
