Thanks Thanks:  3
Likes Likes:  6
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Anyone running 4inch portals on a Yxz1000r ss?
    Ok guys so I bought a set of 4inch portals dirt cheap for a yxz1000r. I had big plans to Fab them up on my rhino 700 but me not having the skill set needed for the Fab work there was only one logical solution, buy a yxz lol. So I bought a 2017 yxz1000r ss se with on 40 miles on her. It already has the 70/30 gear reduction in it and now I'm about to start installing my 4inch portal lift which should give it another 30% gear reduction. Has anyone ran portals on a yxz? I love the machine but where I ride I get into thick mud pretty often and was wondering if after the portals it will turn 30inch tires in the real thick stuff without destroying the clutch. Any input is much appreciated!!!
    Got the fronts on!
  3. Thanks WV Hot Rod Rhino thanked for this post
    Likes WV Hot Rod Rhino, flimmy liked this post
    Vendor flimmy's Avatar
    Mt. Pleasant , Pa
    1,300
    I would say that with the extra 30% reduction you should good with 30's in any mud. Now you wont be going over 40 mph .
    2016 YXZ Yellow SE
    Cleang35's Avatar
    Apr 2015
    Mississippi
    168
    Anxious to hear your results
    2015 Viking VI SE
    So I have been on two rides with the yxz after I installed the 4in portals and it slings the mess out of the 30in outback Max's! 1st gear is crazy low and the ground clearance is incredible even with my shocks all the way relaxed. I'm really happy with them but I wish now I had a lil less reduction in 4th and 5th. Who would I talk to about changing my 5th gear from 30% reduction to 15%? And also it would throw a code every once in a while. It was a transmission code and when it would happen the gear indicator would go blank and wouldn't let me shift gears. Then when coming to a stop it would stall and die. As soon as I turned the key off and back on it would go back to normal!?!
    4 in portals
  8. Likes Timmi, Cleang35, mike liked this post
  9. #7
    tubeworks does the gear modifications.
    Quote Originally Posted by Crank.up.the.boost View Post
  10. Thanks Crank.up.the.boost thanked for this post
  11. #8
    Cleang35's Avatar
    Apr 2015
    Mississippi
    168
    What is your top speed with the portals? I can get maybe 60 with 70/30 and stock 27s
    2015 Viking VI SE
  12. #9
    Mines screaming at 50, but i use the rig for strictly slow trails, mud and rock crawling so it's not that big of deal. If I want speed I have a outlander 1000 to play on lol
  13. Likes Cleang35 liked this post
  14. #10
    Cleang35's Avatar
    Apr 2015
    Mississippi
    168
    Bout the same here. Slow trails and mudd. No rocks though. Was just curious because I do my occasional ride around town on the black top and the exhaust is super loud at high rpm
    2015 Viking VI SE
