I don't know where he got his but here is a pretty good site that has just about anything you want.
http://www.otrattw.com
Steve
Steve
2008 700
SE Rims and seats, JStrong Top, JStrong Doors
JBS Sheave, JBS Splash Guards, Purple Secondary Spring
Cylinder Works +3mm Big Bore Kit (727cc), Gauges, Ryde-on Dust Guard, MSD 3D,
Fan By-Pass (Home made using SteveS' wiring diagram), Horn, Siphon Break, Axia Exhaust Tip
TrailBright LED Lights, Viper 4K Elite Wide Spool Winch
.....And the list keeps growing.....
hi guys is the existing radiator thermoswitch the same thing as the radiator fan motor relay,i can't find the thermoswitch in my teckspark program thanks tex.
07,700 grizzly.
09,700 grizzly.
12,700 rhino.
all camo.
With the 700 they handle the fan control a bit differently than the 660 and 450. The temperature sensor is a low power sensor in the head water jacket. The engine control electronics trips a high power relay when it gets too hot. You can just wire a switch across the contacts of that relay just like you would with the 660's radiator thermoswitch.
hi steves thanks for the info I know right where that is, already have the switch and wire ran so all the rest of the work is in the battery box thanks again tex.
07,700 grizzly.
09,700 grizzly.
12,700 rhino.
all camo.
hi steves got home at 6:30 pm from easter dinner and went and finished my override switch toke 15 min. easy as pie thanks to you just wanted to say thanks again tex.
07,700 grizzly.
09,700 grizzly.
12,700 rhino.
all camo.
