Vendor
Quick release fire extinguisher mount
Might not be of much interest on here but I'm working on a quick release fire extinguisher mount the shroud's the bottle so tree branches and debris can't knock the top off and set it off.I've not watched a sxs go up in flames yet but it I'm not wanting it to be mine.This was just a proto to see how many changes I need to make.I'm waiting on the quick release pin so I can't show it in action.I figured while I was at it I'd do some more hydrographics testing.Go figure it slipped out of my hand when it was first going in so it's a little stretched but I think it turned out pretty good overall.I'll have a kit ready before long.Weld on or clamp on.
08 Resurrected Rhino build and your custom SXS fabrication shop @ Baxter Built Fabrications. Give me a call at 419-953-8509 if you have any questions.
Post Thanks / Like - 0 Thanks, 2 Likes
Looks good Jason. Does the cartridge just drop into the sleeve, much rattling? Would be interested in seeing how it hooks on with clamps....
06/450: Rhino;
JBS Hot Rod Sheave/12gr OD's; Blue Spring; 04 Style/KN Air; Dyna CDI; Axia Exhaust Tip; 3" Lift; Sport Shocks; 27X14 Mudlite XTR's; Warn 2500#
08/700: Rhino;
JBS Hot Rod X-Sheave/16gr OD's/Slugged; Purple Spring; Alba TB; Raptor HotCam; MSD/JBS-Map; Yoshimura Duals; Pro One Doors; LSR MTS; LSR Front & Back Supports; Ricochet Skids; Elka 4's; RackZilla/PS: 26X12 Pitbull Growlers; Camoplast T4S; Viper 4500#;
Trail Bright LEDs.
TOXIC TERYX
Very cool and don't worry mine always slips out of my hand right when I'm putting it in too!
Super Moderator
Vendor
I made it fit pretty tight into the cage so it shouldn't have room to rattle much.Nothing some rub tape can't fix.I might open the rings up that it drops into to put some molding trim in it.Not sure on that yet.It will have a few options.The push button release quick pins are expensive.To bring the cost down I'll prob have a pin go thew with a lanyard attached to a R clip as a cheaper option.U bolts rather than billet clamps and so on.No need to make a fire extinguisher mount break the bank.
