Nice,
Nice,
I'm ready to see how you like the 734cc top end. Mine would run pretty good with 26" Bighorns on the stock aluminum wheels.
were gonna use a megacycle 4 cam with it and you have to clearance the exhaust rocker and the head for the lobes to clear...john at racers edge uses them in the raptor but had never used them in a rhino..on the raptor you dont have to clearance the head just the rocker...i love it!!..and from now on all my heads with be clearanced and deshrouded valves...you would love it chris...wish i had the money to expand as quick as i would like..i need a dyno and a few other tools...lol..i still love field testing for real results though
But how am I going to get my 660 to 734???
2006 Rhino 660
686 Big bore, 11:1 comp, stage 1 cam
Elka stage 3 shocks
Power steering
Innovate AF gauge
Temp,Volt, and Fuel gauges
12" ITP beadlock wheels
26" ITP Terracross tires
Trail bright LED headlights
Trail bright 30" LED light bar
RZR seats with flat aluminum bases & 4 point harnesses
Dual battery set up with battery separator and 8 place fuse block
+4 with 105bore...lol
Thanks for the support you guys. For right now the plan is a nice crank and rod, that monster cam, and some JBS port work on my stock head with factory valves and stock TB. James wants to see if this will get me some good bottom end gains. If it's a flop, we will do the big head and bored TB. Yeah, the mad scientist with the mowhawk is gonna do some experimenting.
I'm so excited, I decided to have a few Bud Ice tonight instead of the light beer. LOL
Thanks for your concern for my well being brother. It sounds good now with the exhaust, but at some rpms it just doesn't sound like the high compression bigger motors. My plan is that the added power will make me drive a little safer as I won't have to drive like a complete idiot to keep up with the big boys so much. But, you know how that usually turns out. LOL
