fabricator
said to myself, screw it. honed stock cylinder and put in a fresh set rings. about 3 hrs later I'm back runnin again.
Now its no panic on gettin the bbk back and installed.
really need rhino around property this time of year, could not wait the most likely month more being down.
she's runnin a little rich. but good enough for the short time stock gear will be used.
didn't think it was worth while screwin with tunin.
09 734 sport, ported, jbs sheave, 16 gram, purple spring, slugged, cam, full muzzy, hi-flow injector, msd 3d, wicked built rack, cognito spindles, hid / rigid industries led lighting, 26" bear claw radials, 2 inch spacers all round, homemade hood rack, doors, bed rails. Always doing more.
Post Thanks / Like - 0 Thanks, 2 Likes
Man that stinks!
Did you figure out why it went down??
Diffenletly looks like lack of lube ??
Good luck
2013 Camo 700 Rhino w/ homemade 4 seater cage, bored and stroke to 804.
11.1cp piston with 105.5 bore, 8mm stroker crank works crank ,25" Bighorn on Viking tactical wheels
BRP cdi , Bazzaz Z FI w/ auto mapper , raptor stage 1 cam ,Yoshimura duals, jBS extreme sheave with 17g OD , slug kit ,injector, Elka stage 1,2" lift , 20" led bar and ez steer
What's the pics of the head gaskets for? What we looking at ?
