Wow!! That turned out nice.... you got some skills with the fiberglass
JBS Powered 09 Camo 450 (The UnderDawg)
That looks awesome, nice job!!
CASPAR
Nice work!
2015 CAMO EPS
OEM FRONT WINDSHIELD
OEM REAR VINYL WINDOW
CFM SPACERS
BED MAT
PRO ARMOR TIRE MOUNT
CARGO NET
KFI WINCH
72" MOOSE PLOW
FENDER FLARES
GLOVEBOX BAG
SEIZMAK MIRRORS
OEM REAR BUMPER
32" LIGHT BAR
STRONGMADE LIFT
30-11-14 SILVERBACK X-LITE
14" STI HD4
LED'S
JBS SHEEVE AND SLUG KIT
2012 blue 700
Fleece. Like those little throw blankets are made out of. My wife picked some up at the fabric dept at Walmart.
I used bondo brand fiberglass resin. Two coats on the front and a thin coat on the plywood on the backside to protect the wood. The two front coats were 16oz each (edit: the fleece sucked the first coat up, I probably didnt use 3oz of the second coat - warning: you only have 10minutes to get this stuff on before it starts setting up). I used 4oz on the backside. After it was dry I sanded it some. Then I used one spray can of rustoleum truck bed coating which gave about 3 coats on the frontside.
Have a look at the link I posted in the first post. It gave me the idea.
The fiberglass is not structural in mine. If you look at the pic before I covered it, you'll see the ring the radio is mounted in is held to the plywood with two pieces of all-thread and two oak dowels. The spekears have 6-32 bolts that go thru the speaker face, speaker ring and plywood.
I'm wiring it now and will try to get a couple Of mounted pics up later or within a day or so.
2012 blue 700
Yeah you can. The harder part for me was engineering the mounting system. If you remove those 4 stainless Allen screws, it hinges down so you can access the wiring. I got it installed yesterday and hooked everything up but then I had to unhook the power and grounds to run up inside of the left cage bar and that was a royal pain in the ass. I still have to hook it back up and there's a trim piece that goes on the side. I ordered the switch below to turn the amp on/off:
So my damn switch hasn't made it yet... But I got all of the wiring done (running wire inside the cage tube - not fun - hate grommets!). Also, even tho I always have my roof on (except right now for this install), I wanted to deflect any rain that might make it to the overhead console. I had a piece of 4x4 pvc fence post. I ripped it on the table saw long ways at the corners and made this - basically 4" angle pvc:
Which I painted and mounted to make this:
Then I made trim pieces for the sides out of some textured ABS I had:
Installed:
Anyway, its all working. I just have a wire hanging down to plug and unplug until my switch arrives. Sound pretty decent for the lower priced components I used.
The ends were an nice finishing touch, nice job!!!
