Thanks Thanks:  3
Likes Likes:  18
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    xample's Avatar
    Apr 2015
    NORTHEAST PA
    73
    Nice work!
    2015 CAMO EPS
    OEM FRONT WINDSHIELD
    OEM REAR VINYL WINDOW
    CFM SPACERS
    BED MAT
    PRO ARMOR TIRE MOUNT
    CARGO NET
    KFI WINCH
    72" MOOSE PLOW
    FENDER FLARES
    GLOVEBOX BAG
    SEIZMAK MIRRORS
    OEM REAR BUMPER
    32" LIGHT BAR
    STRONGMADE LIFT
    30-11-14 SILVERBACK X-LITE
    14" STI HD4
    LED'S
    JBS SHEEVE AND SLUG KIT
  2. Thanks rodneygt thanked for this post
  3. #22
    rodneygt's Avatar
    Summit, MS
    1,131
    Switches
    I had mentioned if you remove the 4 ss Allen bolts, the unit will tilt down. Here's a pic of that - ignore the messy wiring, I was installing my switches and reattaching the roof:
    By the way, if you can see the white ribbon looking thing sort of in the middle behind all the wiring in the top picture, that's the antenna.
    And here's a pic of the switches before I put the roof back on: (Keyed power for the bottom led - with the key on the bottom led comes on. Non-keyed power for the actual switching - so I can run the stereo etc with the key off - top led and accessory comes on when you turn the switch on. For right now I have the stereo switch powering just the amp and I used a relay on that one).
  4. #23
    rodneygt's Avatar
    Summit, MS
    1,131
    Tray light/beer light to go with that second switch. 10watt flood/diffused led - pic:
  5. #24
    that looks sweeet! question, what brand and model is the stereo, and what size of hole does it require?
    thx!
  6. #25
    rodneygt's Avatar
    Summit, MS
    1,131
    Quote Originally Posted by Mjrowley View Post
    thx!
    JBL PRV 175. Oddly most of the info including the instructions say it has one pair of pre amp outputs but it has 2 pair plus the aux inputs.
    It fits a standard marine tachometer hole. 3-3/8" diameter x 3-5/16" (depth). At least that's what the specs said. It had a template and I just used a hole saw that fit the template.
  7. #26
    RhinoFreak's Avatar
    Oct 2016
    tulare, ca
    40
    built my stereo 4 kickers and a kenwood Bluetooth amp
  8. Likes ryanO, Kenny G, madmax 1 liked this post
  9. #27
    rodneygt's Avatar
    Summit, MS
    1,131
    I bet that puts out. Looks good. And like the shifter!
  10. #28
    scottwv's Avatar
    Charleston , WV
    2,193
    Quote Originally Posted by rodneygt View Post
    That looks like a feller might hit his head on that ?!?
  11. #29
    rodneygt's Avatar
    Summit, MS
    1,131
    Lol. He should've just been content to let me go around stuff instead of over!
  12. Likes scottwv liked this post
  13. #30
    RhinoFreak's Avatar
    Oct 2016
    tulare, ca
    40
    It's loud as hell even with a helmet I'm totally pleased with it and only have 300 bucks into it
