wifes rzrS makes a thunk noise
her S developed this thunk noise when u punch it from a stop and if ur barely rollin and punch it and let off it it will thunk then also. its comming from behind that plastic panel where the searbelts come thru. theres no play in the drive shaft so im wondering clutch, ujoints? anyone else ever have this problem its a 13 rzrS le with 45 hrs on it https://m.youtube.com/watch?v=JLeSU_I2OqY
there is no noise if im in neuteral and punch it or if im in reverse
motor mounts maybe ..i have upgraded ones in stock...i think around 100 for all 3...makes them much better..even fixes the exhaust gasket wear issue
My viking made the same noise. It was really bad. I thought the motor was going to fall out of he machine. The parking brake disc was loose. The dealer tightened it up but from time to time i still hear the noise but its nowhere near as bad. Maybe my motor mounts are bad too?
CASPAR
ill check motor mounts tomarrow. hers dont have a parking brake but the pads made a horrible knock also but i have fixed that knock with shims between the pads and pad pins little redneck engineering with mountian dew can but hell it works. thanks for the advise guys. ill keep lookin cause its driving me nuts and last thing i want is something letting loose when she is going up hill if i can prevent it since we go up and down hills like this every time we ride
Super Moderator
Check your welds for the rear diff, jack up the rear so both tires are off the ground and rock the tires back and forth to see if you can pin point where the noise is .
i check today, forgot to mention its only if im in high, if im in low or reverse and punch it no noise
all mounts were tight checked with torque wrench. here is a vid with cover off. anybody know if belt alignment can cause this noise. it is out of alignment per the manual. i will need to pick up a .030 shim on monday and try again https://m.youtube.com/watch?v=ZtSgsueKRlU
changing fluids today and was under the rzr found this drivers side tranny mount. guess thats how the belt got out of alignment. u can see on bottom of center where its been hittin. bet thats the clunk noise rather than the belt. ordered holzracing mounts should have them tues
hmmm,,hotrod was right...glad i could help
