Need help rhino apart !!!!!!
replacing wheel bearings In my rhino right now I am working on the pass front which did not have any play in it im replacing it because the driver side is bad and I want both front new. so here is my problem after getting the old bearings out that had 0 play in em and putting new oem bearings in and bolting everything back up I now have play. how the hell does that happen ? and this is not my first rodeo with wheel bearings I have done atvs , side by sides , trucks , vans etc... never have I put brand new bearings in and had play right away.
Redneck Crazy - 2017 Teryx4 LE , 4" portals , cage chop , arched A arms , 32x10x14 pro armor crawler xg , sti hd beadlocks , winch bumper , 5,000# winch , custom snorkels.
mike
You did put the inner race spacers, didn't you?
in knee deep
oh that sucks. at least your consistent this time of having play in them.
Yeah I know i'm of no real help. lol
any chance the new bearings are bad or not made correctly
Are you use OEM bearings or after market?
2013 Camo 700 Rhino w/ homemade 4 seater cage, bored and stroke to 804.
11.1cp piston with 105.5 bore, 8mm stroker crank works crank ,25" Bighorn on Viking tactical wheels
BRP cdi , Bazzaz Z FI w/ auto mapper , raptor stage 1 cam ,Yoshimura duals, jBS extreme sheave with 17g OD , slug kit ,injector, Elka stage 1,2" lift , 20" led bar and ez steer
in knee deep
DuckHunter
OEM ducky
Just cause ya missed it reading his first post. Hahaha
it doesn't matter anymore. I shot it several times then lit it on fire.....problem solved !!!!
Follow me on Instagram @rdavis512
For updates on the build and other randomness
Old No.7
2015 camo Viking eps
JBS extreme clutch with secret rainbow spring
16" msa throttle wheels wrapped in 35" terms
50" light bar with strobes
Teryx shocks
superatv 4" portals
Strong made lift(3")
Chopped cage 3"
Boss blue tooth amp with 2 4"pods And 2 6" pods
Half windshield
Old no7 build thread
http://hotrodforums.net/forums/showt...?3501-Old-No-7
