Results 1 to 6 of 6
    chaselee's Avatar
    Aug 2015
    Houston
    238
    For you guys running JBS teryxradiator guards
    I'm mocking mine up and it doesn't appear that there's enough room to reach your hand in to turn the knob to freespool the winch. Anybody have the same problem, or k ow of a fix? I know they can be cut, but to cut too much would kind of defeat the purpose.
    2013 Teryx4, 7" custom lift, 32" outback maxx"s, Full muzzy pros, Power Commander 5, JBS Clutching, Triangle ATV snorkels, 3-5 cage chop, Froghead Ind overhead media box, Superwinch terra 4500, JBS radiator guard, Bandit suspension!!
    Clayton, Mi
    3,256
    Pics?
    It's tight but mine work with the Superwinch Terra 4500 and KFI mount. Just reach down from the top and give it a twist.
    2014 KAWI T4 800 GREEN LE
    On my Rhino with the sport bumper, I have to reach in the front and turn it. But if I were deep in mud then I am going to have to open the hood if going in from top. I am a little more complicated cause of some flat LED lights on a bar over the top of the winch. Thinking I may move the lights to outboard of the guards.
  5. #5
    chaselee's Avatar
    Aug 2015
    Houston
    238
    I think i can make them work, but its real tight up against the freespool knob that you cant spin it. I think im just going to have to trim that small piece out to free it up a bit.
  6. #6
    chaselee's Avatar
    Aug 2015
    Houston
    238
    Got it! Had to trim a bit to let the freespool knob work correctly. Pretty nice pieceClick image for larger version.
ID:	6650Click image for larger version.
    Sent from my XT1080 using Tapatalk
