Looking great! Nerf bar sliders?
2016 YXZ Yellow SE
2016 YXZ Yellow SE
nice!
Nice looking work.
Sent from the drivers seat of my truck.
JBS 787, bored throttle body , +1ported head, JBS deshrowded valves,kibble white valve springs, muzzy exshaust,dynatek coil,TCP oil cooler, triple pass radiator,billit one steering rack,heavy duty steering tierods, heim joints,+6 long travel,tilt wheel, radius roll cage, JBS rear splash shield
Bead lock wheels , bear claw tires , power steering
2016 YXZ Yellow SE
I got the rear High Clearance Radius Arms installed over the weekend and I'm working on a short windshield and full windshield to use until I can save up and buy a new JBS one.
Also did a little riding after plowing the driveway yesterday.
Sample of what I started with
After polishing and cutting to size
2016 YXZ Yellow SE
Buy a brace kit for the frame.At least the front one.You won't regret it.I'll have a 14 XP900 in here by weekend working on the chassis and new cage.If you stuff the front wheel in a rut your front tire will be touching plastic.A arm and frames aren't priced that bad from Poalris but a $65.00 lower A arm is still cheaper than a $1600.00 frame and the work that goes into switching them out.
2016 YXZ Yellow SE
