2016 YXZ Yellow SE
I always use a little "Never Seize" or "Anti-seize" on any thread, especially ones that go into aluminum. Works great on Break pin sliders too. Use this stuff on the threads of spark plugs also. You just need a little dab of it, and you will not likely have trouble again.
Use this on most bolts
Attachment 785Use this on Exhaust studs
Its a good idea the use on stainless when bolting to a disimular metals.
2008 700 sport, JBS sheave OD weights,purple spring,MSD,floor guards,sat radio,RydeOn cover,Aluminum stick guards,JBS radiator guards,JBS skid rear,30`and 10`
Trailbright LED`s,K&N,rear window,2`lift,RZR seats...
http://hotrodforums.net/forums/image...ine=1422123669tons of other stuff...
Take that bar off the side of the drivers seat so you can get in & out easy. Screw the passenger, they need to be held in anyway.lol
2008 700 Sport with badass whatyacallits & a HRR sumbitch
If you have a nut that is in a bastard of a spot you can take a piece of paper and put it in the socket and it won't fall out and let you get it started without having to have use your fingers.
Works slick.
Sent from the sticks
2016 YXZ Yellow SE
That does work well I've used it before along with using electrical tape around your swivel to keep them from flopping around every where.
Sent from the drivers seat of my truck.
JBS 787, bored throttle body , +1ported head, JBS deshrowded valves,kibble white valve springs, muzzy exshaust,dynatek coil,TCP oil cooler, triple pass radiator,billit one steering rack,heavy duty steering tierods, heim joints,+6 long travel,tilt wheel, radius roll cage, JBS rear splash shield
Bead lock wheels , bear claw tires , power steering
uh oh.
wait for it...
Mountaineers are Always Free!
08 700
LSR Mid-travel
Dirt logic shocks
Bead lock rims wrapped in 26" Bighorns
30" trailbright light bar
4 seat cage w/rear seats
Muzzy exhaust
Custom intakes
MSD Charge
Rear lights
Still Needed-full doors etc
