Thanks Thanks:  6
Likes Likes:  5
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. #21
    Kenny G's Avatar
    Cowboy State, Wyoming
    3,391
    My comments after installing the Axia 17" panoramic mirror. Great product from Axia, well built, good clear mirror without distortion. But if you're running a custom cage like I have it is limited because of the pillars and bends along the side upper supports. Gives great spotting on the passenger side and behind but you'll need an additional drivers side mirror if you wish to get a clear shot of that area along side you.
ID:	7550   Click image for larger version.
ID:	7551   Click image for larger version.
  2. #22
    Yeah I run the axia too. It's definitely high quality.
    Sent from my SM-G920V using Tapatalk
  3. #23
    chuddly's Avatar
    Indiana
    2,193
    I fabbed this up yesterday. I found an extra 7" LCD screen and backup camera laying around in my garage so im going to make it a rearview camera set up for the rhino. I dont know if I will leave it in there year round but I will make it a quick removal for washing and for big rides (spring ride) to make sure the person behind me is making it still. When your strapped in with harnesses its tough to always see behind you real well.
    2006 Rhino 660
    686 Big bore, 11:1 comp, stage 1 cam
    Elka stage 3 shocks
    Power steering
    Innovate AF gauge
    Temp,Volt, and Fuel gauges
    12" ITP beadlock wheels
    26" ITP Terracross tires
    Trail bright LED headlights
    Trail bright 30" LED light bar
    RZR seats with flat aluminum bases & 4 point harnesses
    Dual battery set up with battery separator and 8 place fuse block
  4. #24
    I like it and its a must. I have to have one so I can see James disappear as I pull away from him. Also helps to see your rear sides as well.
  5. Likes Kenny G liked this post
  6. #25
    in knee deep Snorider's Avatar
    Eastern WA
    2,385
    Quote Originally Posted by chuddly View Post
    I need a better garage. I never have extra cool stuff like that laying around in it.
  7. #26
    chuddly's Avatar
    Indiana
    2,193
    My biggest problem is I have so much junk that I lose perfectly good stuff lol
    2006 Rhino 660
    Elka stage 3 shocks
    Power steering
    Innovate AF gauge
  8. Likes Timmi liked this post
  9. #27
    chuddly's Avatar
    Indiana
    2,193
    Got it hooked up tonight. Should work just fine. Gotta clean up the wires a bit though.
    2006 Rhino 660
    Elka stage 3 shocks
    Power steering
    Innovate AF gauge
