gonna start posting screenshots of different fuel maps to help people tune their 700..if you have any post them here..we needed something like this
[QUOTE=Hump;79862]Stock engine, stage1 Raptor Hotcam, stock exhaust with modified tip. Perfected map with over 1200 miles of riding.
Sent from my SAMSUNG-SGH-I437P using Tapatalk
I've been out of the Rhino tuning scene for a couple of years, but I do still have some MSD 3D maps. My Rhino ran very well with these settings around sea level in Texas. Here are a few screen shots of my fuel, timing, and fuel acceleration maps.
Engine setup:
105.5mm Big Bore
11:1 CP Piston
Rhino Stage 2 Cam
Ported Head with +2 Valves and Kibble White Valve Springs
46mm Throttle Body
Muzzys Dual Exhaust with Whisper Cores installed
I'll add this to the thread as well. Nate from Alba Racing sent me this map to view. He listed this map as compatable with the following mods:
105.5mm Big Bore
Ported Head
Web4 290 Cam
46mm Throttle Body
Dual Exhaust
Intake
James, I am still waiting for you to send me my tune for the Alba exhaust.I finally got my AFR gauge squared away and running in 12.8 - 13.3 range with my stock exhaust with billet tip.
James if you are working on mine, I know its been awhile, so do not forget that I have the Viking fuel injector with the Viking cam.
i will get that for you..nikki will have to load ours here i just wanted to get it started
Thanks for starting this thread James, great idea. Waiting patiently for a map a little closer to my build.
105.5mm bore, 10:1 JE piston, Rhino Stage 2 Hot Cam, 46mm throttle body, Two Brothers Duals, K&N
