What's the biggest tire I can run on my Teryx 4 with a 2" Highlifter lift with my JBS floor guards?
Never mind I found an answer, 30's will have a slight rub with a 2" lift without floor guards. Bummer I found a set of 30" EFX Motoclaws with 400 miles on them for $500. I would probably tip it over anyways lol
They're no good if you're on your roof.
Hey guys, this is a good question, I have a 2" Highlifter lift and got 28" Blackwaters and with the floor guards I have serious rub when turning left with 2" spacers. In my little pea brain I thought these would work, obviously I am wrong. Any ideas on what to do now orrrrr, is it you just can't fix stupid?
I went with SATV Arched A-arms, 2" Highlifter with 28's with my JBS floor guards and everything clears
Thanks Crusty, that was what I was thinkin, just hoping there was a quicker, easier fix, but hey like I said, maybe I can't be fixed!
Could you just remove the front spacers? Maybe try a different wheel offset?
2007 660 JBS sheave, and MSD Charge
As long as the tread is not grabbing a sharp edge or corner of something, a little rub in a sharp turn will not hurt a thing. If it was mine and there was a corner of the guards that the tread blocks were grabbing, I would just take a BFH to it, and keep the guards.
lol no shit huh?
Also forgot to add that I'm running Zero offset wheels but for our Forum ride in Moab I ordered some 2" spacers for all 4 just to be safe lol I don't have a very good record with keeping it rubber side down in Moab.
