Thanks Thanks:  6
Likes Likes:  12
Results 11 to 17 of 17
Thread: smelly cab
    Still Shakin' the Cage 08Rhino450SE's Avatar
    oHio
    2,226
    Quote Originally Posted by madmax 1 View Post
    damn it Theresa!!, lmao, maybe i'll check the pipes and see if I can find the cause or some vents on the top of my windshield, thanks guys
    good thing she doesn't read this. you'd be getting lumps on the noggin'
    bran flakes work wonders lmao
    Mountaineers are Always Free!
  2. Likes madmax 1 liked this post
  3. #12
    madmax 1's Avatar
    frostburg md
    4,019
    Quote Originally Posted by 08Rhino450SE View Post
    lmao, you are so right on both counts Denny
  4. #13
    Hump's Avatar
    Richwood, wv
    2,087
    I don't have any exhaust leaks that I can find now, and mine still gets stinky at low speeds when I get in and out of the throttle a lot. I run a windshield with the bottom 8" cut out in warm weather and have no problems. I really hate it, but had it a little bit with stock exhaust also, just not near as bad. There is absolutely no air moving in the cab with the back and front closed in. Seems the wind goes around the rear and circles back in the sides and gets stuck under your nose. It is the one thing that pisses me off about my rhino. When it gets cold out, it just makes me want to get rid of it. I wish there was a way to get completely rid of it, but I think it's an aerodynamics thing. I have wondered if I had some long tailpipes that went all the way to the end of the bed if that would help...
  5. Likes madmax 1 liked this post
  6. #14
    Hump's Avatar
    Richwood, wv
    2,087
    I'm very sensitive to the fumes, get all kinda screwed up in 3 hrs or so if we are going slow for very long.
  7. #15
    BIGOOZ's Avatar
    Sep 2014
    OHIO
    894
    My cab usually smells of pussy. But that's a good thing
  8. Likes madmax 1 liked this post
  9. #16
    CA Redneck ASPENDELLROVER's Avatar
    Coyote Flats
    2,552
    Quote Originally Posted by BIGOOZ View Post
    like a shit house on a tuna boat...lmao
    Sent from my momma's basement
    "The family Comfort Wagon"..JBS sheave, +6 LT w/kings, 4 seat cage w/3 twisted stitch seats
  10. Likes madmax 1 liked this post
  11. #17
    Coyote Flats
    2,552
    Quote Originally Posted by scottwv View Post
    The cover will help a little ; but , it doesn't eliminate it . The inlets on the mufflers are leaking on mine (muzzy's)...I have some 1 1/4 aluminum pipe to weld in them , just haven't taken the time to fix them .
    prolly due to slow Wv pace on the trails
  12. Likes scottwv, madmax 1 liked this post
