I believe that is Sean from tubeworks
I got to drive a yxz today with the tube works gears........ BADASS
Follow me on Instagram @rdavis512
For updates on the build and other randomness
Old No.7
2015 camo Viking eps
JBS extreme clutch with secret rainbow spring
16" msa throttle wheels wrapped in 35" terms
50" light bar with strobes
Teryx shocks
superatv 4" portals
Strong made lift(3")
Chopped cage 3"
Boss blue tooth amp with 2 4"pods And 2 6" pods
Half windshield
Old no7 build thread
http://hotrodforums.net/forums/showt...?3501-Old-No-7
Our gear kit is just like changing the ring and pinions out, but with a wider speed range in the transmission. This mod gives you the same effect as taking the stock 3.66 gears out and installing a 6.20 :1 gear for 1st, and having a 4.70:1 for 2nd to 5th + reverse. We had near 90 mph on the stock tune. We also tested a dual spring pressure plate mod on a rekluse, and absolutely loved the pedal feel and holding capacity.
