Likes Likes:  1
Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Feb 2016
    Oklahoma
    30
    Extra Battery Question
    Has anyone heard or seen using a stock battery box on the driver side the hold an extra battery?
    Looking for ideas on putting an extra battery on my 2012 Rhino 700.
    Rob
    Still Shakin' the Cage 08Rhino450SE's Avatar
    oHio
    2,226
    i haven't done it to mine, but most guys put them close to the stock battery location to facilitate wiring and mounting.
    if you do a search in the electrical section there's a lot of different ways to do it.
    in the interim i'll see if i can find you a thread.
    here's two
    http://hotrodforums.net/forums/showt...50-Which-setup
    http://hotrodforums.net/forums/showt...tery-separator
    Mountaineers are Always Free!
    1,636
    I do recall at least one post showing a modified Rhino battery box positioned in a new location. It was either in the center or on the driver's side, but I don't really recall which. You should be able to find it, hopefully in the Rhino electrical section.
    Another spot, where you can fit a much larger battery, is under the driver's seat. There will be posts in the same electrical section.
    rodneygt's Avatar
    Summit, MS
    1,131
    That's mine Steve. It's in the middle. Fit as if it were designed to go there - after I cut the little side piece off with my table saw. I'm not sure how the newer ones are made but the batt box is different post-07 and I think the newer rhinos have the air filter box or something in the middle?
  5. Thanks SteveS thanked for this post
    i have a optima mounted in the front middle. Im using this as my isolator. http://www.quadboss.com/battery-isolator.html
    Double T Mudbusters jd283's Avatar
    Dec 2014
    Tatum tx
    838
    http://www.gearup2go.com/default/yam...FZeEaQodY3ABDQ
    Found this as good option if you want a mount, probably more out there and maybe cheaper. Me I would make a hold down bracket and mount it under seat. Just make sure its a 100 percent sealed battery like an optima. even the cost of the extra wire would offset buying a mount and you could use any battery size.
    2012 blue 700
  8. #7
    txgrown1404's Avatar
    wichita falls, tx
    1,923
  9. #8
    Feb 2016
    Oklahoma
    30
    thanks guys. i was thinking about mounting it under the drivers seat since there is more room.
    2012 rhino 700. 3" lift kit, stock wheel and tires, 3000# warn, top, custom stereo.
  10. #9
    Vendor flimmy's Avatar
    Mt. Pleasant , Pa
    1,300
    Get the TrueAm isolator we sell . It's a better isolator then the quad boss and cheaper.
    http://www.trailbrightled.com/Switch...sses-_c_8.html
    2016 YXZ Yellow SE
  11. Likes Timmi liked this post
  12. #10
    Feb 2016
    Oklahoma
    30
    already ordered the isolator from trail bright!!!
