Results 1 to 4 of 4
    Mar 2016
    Lincoln Nebraska
    25
    Split case and found parts??? HELP
    I bought a 700 grizzly for the case but found my rod was bad as well on mine so would like to try and use that as well. Problem is that i found 15 of these in the bottom of the case when i split it to put in the Rhino gears and reverse upgrade. Does anyone know where these could have came from. I checked the needle bearing in the clutch drum and the one in the transmission assembly and the are both ok. The crank rod seems tight and smooth but I dont know how they could come out of there without destroying something. I have looked through all the diagrams and cannot find anything. Any help would be appreciated.
    THanks
    DuckHunter's Avatar
    Apr 2015
    Maine
    290
    They look pretty rusty for being under oil in bottom of motor ??
    2013 Camo 700 Rhino w/ homemade 4 seater cage, bored and stroke to 804.
    11.1cp piston with 105.5 bore, 8mm stroker crank works crank ,25" Bighorn on Viking tactical wheels
    BRP cdi , Bazzaz Z FI w/ auto mapper , raptor stage 1 cam ,Yoshimura duals, jBS extreme sheave with 17g OD , slug kit ,injector, Elka stage 1,2" lift , 20" led bar and ez steer
    in knee deep Snorider's Avatar
    Eastern WA
    2,385
    I wonder if they didn't lose a rod before and did a piss poor cleaning job when it went back together. With everything else being good, I'm just throwing a SWAG out
    could be out of one of the tranny gear bearings
Tags for this Thread
