Results 1 to 3 of 3
    Barnett Clutch Plate Kit for Yamaha YXZ1000R
    New clutch plate kit for the 2016 Yamaha YXZ1000R includes a complete set of 11 Kevlar friction plates and 10 tempered steel plates. This kit is a direct upgrade replacement for the stock clutch plates and provides a smoother and more positive clutch engagement. Each kit is made in the USA and quality checked for exact stack height to guarantee optimal fit and performance. To order, contact your dealer order online at www.barnettclutches.com.
    Part #306-90-10092
    MSRP: $232
    New Barnett Clutch Spring Conversion Kit Yamaha YXZ1000R
    The newest addition to our line of Yamaha clutch spring conversion kits is our new kit for the 2016 YXZ1000R SXS. Like our other spring conversion kits, this kit converts the stock diaphragm type clutch spring and cast pressure plate to six heavy duty coil springs and a pressure plate CNC precision machined from billet aluminum. This provides a more controllable, linear clutch engagement and is superior in durability compared to stock. Installation is 'bolt-on' with NO modifications required. It simply replaces the stock pressure plate/spring assembly. Included in the kit are the six heavy duty springs, billet pressure plate, spring cups and stainless screws. A clutch plate kit (#306-90-10092) is also available and sold separately. Made in the USA. To order, contact your dealer or order online at www.barnettclutches.com.
    Part #511-90-10010
    MSRP: $141.63
    Contact:
    Barnett Clutches & Cables
    2238 Palma Dr.
    Ventura, CA 93003
    Ph: 805-642-9435
    Clayton, Mi
    3,256
    Are people going through OEM clutches?
    First and reverse gear ratio are too high
    Yamaha needs to correct it immediately
