Thanks Thanks:  5
Likes Likes:  24
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
    May have a problem with my jbs clutch kit
    So I have finally been able to get a few good rides in with the new clutch kit, but didn't really notice much on the bottom and lost about 10 to 15 mph up top. Wondering if I got some wrong parts or if the shop that did the install did it wrong.
    Is the bottom end take off a big difference from stock? Is it normal to lose top speed with this clutch kit?
    I believe I got the extreme clutch kit and I'm running on 28 inch Blackwater Evolution Tire.
    Thanks!
    Apr 2015
    Northern Tip of WV
    514
    Need some info on bike??
    06 Rhino 686 s/e blue, 11:1 piston, stage 1 hot cam, raptor springs, JBS sheave and clutching, cmf 2" lift, alum air box, exhaust tip, dial a jet, j strong roof, ride on dust shield, power steering, Stage 5 Elka's riding on 28" 11 14 mega mayhems all around on sti hd3 wheels, hp cooling fan, 3500# winch, 32" led light bar and stuff!
  3. Likes robleticia liked this post
    Hump's Avatar
    Richwood, wv
    2,087
    You should have gained a good bit of power overall, and a decent increase in top speed. Something went wrong with the install.
  5. Thanks WV Hot Rod Rhino thanked for this post
  6. #4
    Double T Mudbusters jd283's Avatar
    Dec 2014
    Tatum tx
    838
    call the mechanic that did the install tell him to go to jbs website and see if they installed weights etc. correctly
    2012 blue 700
  7. Thanks WV Hot Rod Rhino thanked for this post
  8. #5
    rodneygt's Avatar
    Summit, MS
    1,131
    I'm no mechanic but installed mine myself. I gained pulling power and a few mph top end. It's easy to flop a weight so that your top end is limited and/or get too much grease. Something is wrong with your install.
  9. Likes WV Hot Rod Rhino liked this post
  10. #6
    Banned
    Angleton, TX
    3,399
    If you lost 10-15 on the top, you flopped a weight probably
  11. Likes WV Hot Rod Rhino liked this post
  12. #7
    Banned
    Angleton, TX
    3,399
    I send my customers this to make sure they get them right. You're going to have to open it back up and look, cause something isn't right
  13. Thanks WV Hot Rod Rhino thanked for this post
    Likes Timmi, DuckHunter, Hump, Fabricator, madmax 1 liked this post
  14. #8
    James has a video, maybe several, about keeping the camplate pressed against the sliders while installing to prevent the slider weight from moving. It's an easy mistake to make if you're not experienced with doing them.
  15. #9
    Hump's Avatar
    Richwood, wv
    2,087
    I made that mistake the 1st two times I ever done it. Both times I swore nothing went wrong. It's one of those things that is awkward at 1st, but is very easy after you do it a few times. Everyone should buy the tools needed, and learn to service their clutch. I wouldn't let any of the dealerships around here ever touch my Rhino. Not ever!
  16. Likes jd283 liked this post
  17. #10
    I flopped weights 1st time install, never again. Gets easier everytime from then on. Cheers
