Double T Mudbusters
I have tore into my primary a few times but none made me more nervous than the X sheave with the shim. I took 3 stabs at it then decided to get a wrench handy so when i had it all like i wanted with my thumb on camplate i tightened with wrench after finger tight.
2012 blue 700
A Very Bad Monkey
Timmi
James has a video, maybe several, about keeping the camplate pressed against the sliders while installing to prevent the slider weight from moving. It's an easy mistake to make if you're not experienced with doing them.
I need to see this. All I am doing is adding a JBS shim and changing the oil this weekend, but don't want to mess something up.
2014 Green EPS Viking
Superwinch 4500
Denali Pro Plow
27" Interforce F & 28" Zillas R
ITP Delta 5+2 Wheels
Spring Spacers
UTV HQ Vent Windshield & Encl
EMP Wiper & Rear Bumper
Summit Racing Heater
YXZ SE Seats
JBS Guards,Skids & Sheave
4-Point Harnesses
Ultra Halogen Headlights
24" Light Bar
Power Sub-Panel
LEDXTREME Whip
Backup Camera & CREE Lights
Accent LEDs
Sound Dampening Kit
Center Console
Seizmik Mirrors
Extinguisher
TSC Bed Mat
Spare Carrier
here is one vid of James changing it out. notice at 55:23 he never lets go of the camplate until the nut is snug
BadM0nkey
A Very Bad Monkey
Timmi
Thanks Timmi
Superwinch 4500
Denali Pro Plow
Spring Spacers
YXZ SE Seats
4-Point Harnesses
24" Light Bar
Power Sub-Panel
LEDXTREME Whip
Accent LEDs
Sound Dampening Kit
Center Console
Seizmik Mirrors
Extinguisher
TSC Bed Mat
Spare Carrier
M0nkey, you have my cell #, call me if you have any questions or problems
Diy
I second the notion of not letting the dealer work on your machine!!! the Yamaha mechanics here in Hot Springs, AR are a JOKE. I took my Viking to get the radio installed and they didn't even tighten the bolts down on the roof, luckily I found them scattered around the floor of the trailer. There is no way I would let them touch anything important. Plus I'm the kind of guy that likes to know how and why stuff works. My shop is always open so I'm not at the mercy of someone else's schedule. Always DIY!!! The experience is worth it's weight in gold.
Post Thanks / Like - 1 Thanks, 2 Likes, 0 Dislikes
Well when you think about it, Yamaha mechanics install round roller weights that are hard to flop, unless they have experience with OD weights and JBS sheaves how would they know to look out for weight flopping due to camplate lack of pressure. Cheers
thanks all for the answers...did you get it fixed?
A Very Bad Monkey
robleticia
Thanks Rob, I will. I was just concerned with your prior warning and then this thread about the weights moving. I will just keep pressure on it with one hand while I put on the shim with the other. I need to dig out my little torque wrench and caliper (for the belt).
Superwinch 4500
Denali Pro Plow
Spring Spacers
YXZ SE Seats
4-Point Harnesses
24" Light Bar
Power Sub-Panel
LEDXTREME Whip
Accent LEDs
Sound Dampening Kit
Center Console
Seizmik Mirrors
Extinguisher
TSC Bed Mat
Spare Carrier
BadM0nkey
Where are you putting the shim ??? It goes between the fixed and the collar...you shouldn't be concerned with it when putting the primary on !
