Not sure I've ever hit the limiter.
Here's the badm0nkey math based on my tire/wheel upgrade:
The circumference of a tire is how far you travel per 1 axle revolution.
The circumference of a 25" Tire is 25" x 3.14159 = 78.54"
The circumference of a 29.5" Tire is 29.5" x 3.14159 = 92.68"
The 29.5" Tire has a circumference which is 18% greater than the 25" tire so at the same RPM (Speedo Reading) I'm going 18% farther.
If Speedo reads 46 mph and was properly calibrated for a 25" tire, I will really be going 54.28 mph. If Speedo reads 50 mph, you are really going 59 mph.
I'm going 46 down hill and 43 back uphill. Split the diff and bluebanger's going 52.5 mph.
Thanks guys. I believe you answered my question. Running out of steam before it hits limiter. I am very pleased with my set-up. Just noticed it was not hitting limiter and thought I goofed up the install. Thanks
bd_skrillz
I need an a Boeing landing strip to get to that speed. I haven't done it in a while since there's not enough flat, straight aways round my parts.
I know what you saying. I was on the paved road in front of my house with a slight downhill.
Now that I have a little time with my setup I would like to try to tune it for a little more low to mid range. Thinking of trying a gold spring or 15g o.d weights. (My set up now is in my sig). Anybody tried the gold or 15s in the wolvy yet?
2016 Base Wolverine, 27" Bear Claw HTR's, JBS Hot Rod X-Sheave/16gr OD's/Slugged/Purple Spring, Mud Busters extended fenders, EZ Steer eps kit, Yamaha folding winshield, Yamaha soft rear window, YXZ Steering Wheel, Ricochet A-Arm guards, 3500lb Warn winch.
I don't know of anyone running 15's in a wolvy
my 16's spool up fast
Yep mine does awesome. Jut got the hankering to tweak it a little to see what it likes. I have never tinkered with weights or springs before. Something new to me. But I have been on dirt bikes/atv' for over 30yrs.
that's about all "clutch kits" consisted of for years, weights and springs
393stroker
Yep I have always been on a honda. Cr125,cr250,xr250 dirt bikes. Honda foreman,rincon for atv's. I still have a like new honda pioneer 500 also but it don't see much seat time since the wolvy purchase.
how does the 500p ride? they have a full auto trans option now
393stroker
It is very stiff with little travel. It is nice on very tight atv trails. But I use it mainly for yard work. Pulling scrape on gravel drive and pulling pull behind mower. It was my first SxS moving from rincon. I quickly realized this was not what I had in mind for a SxS. It is very tippy in off camber situations that I don't even pay attention to in the wolvy. But the main thing I like about it is the low gear and the paddle shift. It is basically a honda foreman with a golf cart body in my opinion.
