Likes Likes:  2
Results 1 to 5 of 5
    Riding for the Big Guy!
    Apr 2014
    Rock Cave, WV
    108
    RZR axles and wheel bearings
    My MIL has a 14 RZR XC and both rear wheel bearings are shot and the outer cv on one is shot. I'm not teryx guy so I don't know much about aftermarket on these. Is there a better wheel bearings than oem? And would I be better of getting a new axle instead of replacing the cv? If so, what brand?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Texas (Victoria area)
    661
    In my opinion, the Polaris bearings are better. I've run the All Balls brand bearings and they just don't hold up as well. As far as the CV, I'd lean toward replacing the entire axle with a Rhino axle or the lower cost ADR axle, both from SuperATV. The Rhino axle is a little more expensive but has a better boot.
  3. Likes Timmi, 08Rhino450SE liked this post
    Apr 2014
    Rock Cave, WV
    108
    Quote Originally Posted by Chris View Post
    Thanks Chris.
    Hump's Avatar
    Richwood, wv
    2,087
    I ran a rhino brand axle in the one I had. Fit great, and worked like it should. Priced right too. Don't know about the wheel bearings, didn't keep it long enough to replace them. I would say go oem on those.
    Apr 2014
    Rock Cave, WV
    108
    Quote Originally Posted by Hump View Post
    Thanks Hump. Rhino axle showed up next day from Super ATV. Went ahead and got bearings from them too.
