Likes Likes:  4
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Yamaha viking hp spal radiator cooling fan
    Just wondered if anyone upgraded to this aftermarket fan for the their Viking.
    http://www.universalpartsinc.com/sho...aspx?i=1077651
    If you have, did you need to change the circuit breaker? They mention in the details that it ma require a higher amp circuit breaker or fuse. The fan fuse is 25 amps so I believe that should be good, but the electrical diagram shows a circuit breaker between the fan relay and the fan (unless that circuit breaker is internal to the fan I haven't checked).
    Any feedback would be great. Thanks!
    I have had one in for a month now, no issues just great cooling. OEM died after 120hrs. Cheers
    Apr 2015
    Northern Tip of WV
    514
    Have had one in my Rhino for over a year now and its still going strong!
    06 Rhino 686 s/e blue, 11:1 piston, stage 1 hot cam, raptor springs, JBS sheave and clutching, cmf 2" lift, alum air box, exhaust tip, dial a jet, j strong roof, ride on dust shield, power steering, Stage 5 Elka's riding on 28" 11 14 mega mayhems all around on sti hd3 wheels, hp cooling fan, 3500# winch, 32" led light bar and stuff!
    Awesome! Thanks for the info everyone. I went ahead and ordered it. I'm hoping I can get it mounted without having to open the cooling system.
    With the rad in the front and the engine in the back I'm betting that system is a PITA to burp.
  5. #5
    Jack the front end high up in the air when burping. JBS has a video. Cheers
  6. Likes Timmi liked this post
    Janesville, Wisconsin
    316
    Pulling an old thread back to the surface... I see a lot of fans die and cause major problems. Getting ready to take a big trip in a couple of weeks with my big Viking VI. The machine is a 2015, I don't run in the water and don't go mudding...but I have 105 hrs and 1500 miles on the machine. Would hate to go 800+ miles and melt her down over the cooling fan...
  8. #7
    the vent tubes get clogged and kill the bearing. extend the vent tube and and point the open end down
  9. Likes jimclemjr liked this post
  10. #8
    316
    So I am hearing that I should be good (or as good as the stock fan can be) then...mine is already routed a little better and has the end (with a good chunk) facing down. Pulled it off the other day and blew everything out to keep the dust out. Seems to be working ok at this point.
    This is a bigger purchase at this time, so I will likely hope for the best on our trip and look to get one this summer...
  11. #9
    buckg2's Avatar
    Mar 2015
    Howard, PA
    161
    I just put that fan in mine. My stock one quit working. Some WD-40 in the vent tube once in a while and you should be good to go. What happens is the brushes inside corrode and get stuck back.
  12. Likes jimclemjr liked this post
  13. #10
    I put the spal fan on my Viking and that thing moves some air. I also bypassed the factory cooling fan circuitry and plumbed in my own temp switch which triggers a relay to run fan.
