09 700 with a 727 big bore cp 10.75:1 , ported and polished head, throttle body, stage 3 cam, +1valves, msd cdi, alba exhaust, JBS sheave kit with 17g weights, gold spring, fabtech long arm, gorilla axles, four seater cage, seats 4 point harnesses, led lights, full skid plates, 27" ITPs on beadlocks, power steering, aluminum radiator, 4500 lb winch w/synthetic rope, aluminum bed. water and oil temp and oil pressure gauges, half windshield, light bar. now has a slug kit and a bigger injector
No problem my wifes was way out of alignment rack is good
I think I may have found the problem
Sent from my VS986 using Tapatalk
It was really wore out all ready, but I was missing a bolt so I think that's why it broke,
The mounting bolts are worth checking periodically, I have seen them come loose. Not worried about factory setup as much as a PO if they messed with it.
