Now that she's on the bench the real fun begins
I've got the shop manual but if anyone has any suggestions on the best way to attack i'd sure appreciate it.
Good clean work space to lay everything out in the order you take it apart will do wonders when you go to put it back together. And now would be a good time to give a good cleaning so it all pretty when you put it back in lol
Follow me on Instagram @rdavis512
For updates on the build and other randomness
Old No.7
2015 camo Viking eps
JBS extreme clutch with secret rainbow spring
16" msa throttle wheels wrapped in 35" terms
50" light bar with strobes
Teryx shocks
superatv 4" portals
Strong made lift(3")
Chopped cage 3"
Boss blue tooth amp with 2 4"pods And 2 6" pods
Half windshield
Old no7 build thread
http://hotrodforums.net/forums/showt...?3501-Old-No-7
You don't have to pull the stator side apart if you don't want too
And I'm in. Wasn't nothing like I was expecting.
So was it as bad as you though? Any details ? We're your bolts loose ?
got some buildup on the piston and valves
