Anyone know what size the radiator hoses are? Im looking at some kits and want to make sure i get the right size sensor fitting.
22 mm
Sent from my XT1254 using Tapatalk
Ended up going with the Trail Tech kit.
Also comes with the 2 clamps and a power cord for the digital display.
Nate Martinez from Alba sent me one if I ever get it installed.
Hillbilly or Timmi, did you get these installed? Work Ok? I was thinking about getting one also.
2016 Yamaha Wolverine R-Spec SE. 12" double row LED's from Flimmy, Warn Vantage 3000, SSV works audio system.......I need to add more parts!!!!!
That’s the set up I put on my Viking and I like it. It is not backlight that is the only thing I didn’t like. I made a little bracket over my gauge with some smell accent LED’s hide underneath that come on with lights so I can see it at night.
Still have not gotten mine installed. My bike has been at James since last April.
I am on the bubble about choosing between an electrical and mechanical water temp gauge. Most electric gauges have at most a 90 deg sweep but easy to find a mechanical with 270 deg sweep which helps discern at a quicker glance what temp is. I wonder what the responsiveness is in time delay of how long a 72" capillary tube takes to get the reading to gauge face? Any input or opinions?
