Likes Likes:  6
Results 1 to 4 of 4
    Viking front bumper build
    Been toying with the idea of building a bumper for my bike for quite a while but never got around to it. I bought a winch mounting bracket that mounted to the stock bumper and installed it, i went to install the winch and the bolts that mounted the bracket to the bumper were in the way of mounting the winch so i said to hell with it and bought material to build a bumper.
    This is what i came up with, I ended up using 2" 11 gauge tubing for the frame and 3/16" plate to skin it........ to be honest its insanely overbuilt and if i were to do it again i would go with 3/4" tubing for the frame.
    Im still toying with a few more options/changes to it including shortening up both ends about 4" each and adding a bull bar of some sort to come up and out in front of the winch. Im also going to add two flushmount led light pods between the d rings in the next week.
    Any opinions/ideas are welcome.
    Sent from my SM-G900V using Tapatalk
  2. Thanks WV Hot Rod Rhino thanked for this post
    should be stout!
    It does look stout as hell. That's kind of the same direction I went with my bumpers that I built for mine.
    Sent from my iPad using Tapatalk
  5. Likes 08Rhino450SE, WV Hot Rod Rhino liked this post
  6. #4
    I ended up cutting this one down quite a bit to knock some weight off, pretty happy with how it turned out.
  7. Likes WV Hot Rod Rhino liked this post
