Thanks Thanks:  2
Likes Likes:  7
Page 1 of 2 12 LastLast
Results 1 to 10 of 19
    Yamaha gytr torque assist gear kit for the yxz1000r
    The GYTR Torque Assist Gear Kit is designed to aid your YXZ1000R through the most rugged, technical and diverse terrain. This innovative system reduces overall gearing, providing enhanced torque control. The GYTR kit reduces the YXZ1000R’s final gearing by 30 percent for balanced close-ratio performance, as well as an additional 40 percent to first gear for ultimate low-speed crawling.
    The GYTR Torque Assist Gear Kit includes a CNC-machined OEM transmission case to eliminate the need for grinding, modification or outside machining, an adjustable speedometer calibrator for precise speedometer readings in YXZs with aftermarket tire sizes, and all genuine Yamaha parts and components necessary for installation.
    GYTR’s Torque Assist Gear Kit is available for the YXZ1000R and YXZ1000R SS through the Yamaha Genuine Parts and Accessories catalog and dealer installation recommended, but not required.
    The Torque Assist Gear Kit provides 30% reduction (70% 1st gear) vs. stock gearing when your terrain demands the ultimate accessory for low speed and tight trail riding. It stands out by providing all the necessary Yamaha Genuine Parts required (*Yamalube sold separately) for installation. The optimized MCU (YXZ1000R SS only), factory pre-machined case, all Yamaha Genuine bearings, precision cut gears, speedometer calibrator, and gaskets are included. There is no grinding, shipping of the transmission or guesswork involved!
    GYTR Torque Assist Gear Kit Features:
    • 30% reduction on original gearing for balanced close ratio performance
    • 70% reduction to 1st gear from OEM for ultimate low speed crawling
    • Includes new MCU (shift computer for YXZ1000R SS only) optimized for use with the Gear Reduction System for perfect shifts in all situations
    • The speedometer calibrator provides the ability to adapt to various tire sizes for precise speedometer reading
    • Works great with various Yamaha offered tire sizes (26”-31”) allowing you to dial in your exact tire setup/size
    • Yamaha Genuine Accessory Tire Kits, available exclusively through Yamaha, are highly recommended and perfectly matched for the ultimate riding experience
    • Dealer installation recommended
    Price:
    • $999.99 for YXZ1000R (2HC-E7530-V0-00)
    • $1,299.99 for YXZ1000R SS (B57-E7530-V0-00)
    Fitments:
    Part # 2HC-E7530-V0-00
    YXZ1000R(2017, 2016)
    YXZ1000R SE(2017)
    Part # B57-E7530-V0-00
    YXZ1000R EPS SS SE(2017)
    YXZ1000R SS(2017)
    YXZ1000R SS SE(2017)
    getting it for ours soon
  4. Likes flimmy liked this post
  5. #3
    I've seen them for less money than this
  6. #4
    my price is a couple hundred less
  7. Likes flimmy liked this post
  8. #5
    Jul 2015
    Ohio
    740
    I thought you already your tubes works edition? or did you only do a partial ?
  9. #6
    A buddy paid a dealership $1,100 installed for the kit on a new YXZ. He got the extended warranty on the machine and wanted the dealership to do all the work so there would be no questions on the GYTR with the warranty down the road. Not sure what the normal labor cost is for installation but seemed like it took quite a bit of work as the dealership had it several days.
  10. Likes Timmi liked this post
  11. #7
    That's not bad at all on price for it installed
  12. #8
    Quote Originally Posted by jerhomey View Post
    Only first
  13. Likes jerhomey liked this post
  14. #9
  15. Thanks WV Hot Rod Rhino thanked for this post
  16. #10
    Cleang35's Avatar
    Apr 2015
    Mississippi
    168
    Found kit for bout 850. My dealer said $2500 just to install they are crazy
    2015 Viking VI SE
Tags for this Thread
