Kinda what I thought.
2" Super ATV lift
Pyle audio system
Yamaha over fenders
4" cage chop
27" tusk Terabites
JBS extreme sheave
16g OD weights
Purple Eibach Spring
Slugs
It's on now!
I would like to know what Hotcams is waiting on. The demand is there, they will sell the hell out of a good set of cams for the Wolverine. If you have ever driven a rhino without and with a cam, you know that the wolverine will have really nice gains from a good upgrade. It has the same feeling, good power, but just doesn't build as you lay in the throttle and hold it down.
Gotta finish the 3 motors in the shop now then it's time!!!
Keep us posted on the gains!
it's gonna be a beast!
I'm saving my pennies for a build.
whatever came of this ?
Yeah, what did happen with the cams?
2016 Wolverine Rspec SE
Superwinch Terra 45s
EMP Rear window
EMP Winch mount
Yamaha Cargo Box
27x9x12 ITP Blackwater Evolution
ITP C series wheels
Perfex 2" lift
YXZ SE seats
James has bbk's for the 708. Weller is the only place I know of that did cams, they were special order from what I remember.
