Rolling chassis
So I decided to take more work. A friend and I bought an 07 660 that had caught fire. The cab was totaled but the frame and suspension are in perfect shape. Got it home and discovered a couple surprises. First I saw it had a supercharger installed but the computer has been burned up. Second is the yoshi exhaust. Is it loud? Will soon find out lol. Was curious about an air intake with That. Will stock work? I bought this for the frame since mine is bent. So pics will follow as I get it all back together
Keep us updated with some pictures.
Nice..I have a few extra 660 pieces laying around
Never realised how much work it is to dismantle one of these lol. Especially with melted plastics in everything. But should be able to start the reassembly today. Put my motor and wiring harness in. Finish removing the 3" lift on rear end.
that yellow, is that the wide body panels?
At first I was going to advise you to be sure you check the frame as heat can degrade the steel temper and lose strength...but then looked at pics and it does not look like it got that hot due to what is left. And with shocks, tires etc looks like you may have got a good deal for the price of a few swap parts. Hope it comes out good for you....
The heat never got to the frame. The floor boards were barely melted. No the plastics are just the normal ones. We had it running last night. That yoshi exhaust sounds awesome. Can't wait to take it for a ride
I got some floor boards
Mite need to re-enforce my floor. Had a stick come through the passenger side last night as I was testing the new build set-up. I do have a a problem tho. My speed is down to about 38 mph. The changes ice made are 27" swamp lites and a yoshimura dual exhaust. And the header was glowing red. Can't upload a pic. Have a 686 with James' extreme shelve with orange spring and 14g weights and stock air filter in it. What would I need to change?
