Big tire weight kit for the x4
so you would run those instead of Dr pulley ?
Just testing it all both ways since everything is different now. Power. torque .sheave size the way the tracks are angled.. so im testing overdrive's against round weights to make sure which one is the fastest and best torque...on the Rhino and The Grizzlies and the Wolverines and Vikings the overdrive's are faster just want to make sure it's the same on the X 4..
And I want to test Yamaha set up also
Do they make more then one size of those weights or just one choice from yamaha ?
a true engineer knows o.d.weights are inherently defective due to their form
Alba won the Baja with a jbs sheave and od's....round weights in a modded rhino sheave SUCKS.. anybody that ever seen our rhino run knows it's the deal and that's with overdrive weights..
^^^What he said. Just ask anyone who ever tried to get me off their ass and they will tell you who to take your Yamaha to.
This thing is a beast now!!!!!
