MSD setting# help
I have my 2008 700. And MSD from way back 2011 maybe. I moved to a way lower altitude town. Went for a ride few days ago and my muzzys were cooking. Even started to melt my tail gate spring holder. Not sure if anyone. Including James would remember what the settings are. Mines at 6. Right now. And probably too lean. MSD was turned by James. I think. Or the alba tune . Thanks in advance.
MSD setting# help
These r the settings for msd#4243
MSD setting# help
I have an 09 with web cam, bored throttle body, duel muzzy's, afe intake, stock piston. Im at 2,000 feet this is my map
Alba said its good up to 6,000 feet. Just got back from colorado and utah was up to 12,000feet had no problem. Im on setting #7 with rpm limit set at 7,800 and advance is set at zero
Brian lee Rhino450
And it idles good with that?
Ya, it surges a little when cold on startup but after a minute or 2 it smooths out
MSD setting# help
Last year we talked on phone was having little start issue and u had me drop that dot at 1,600 to -5. I just raised that dot for our trip
Installing this today so i can actually see where im at
Got gauge installed its at 11.5 at idle but havent drove yet, steering rack is out
Brian lee Rhino450
That’s a Little Rich at idle. Should be around 12.5-13
MSD setting# help
txgrown1404
Prolly why James had me drop it down before, i can drop that 1600 dot down tomarrow and recheck, thanks Michael
0 fuel at idle with a cam is usually off
