Thanks Thanks:  3
Likes Likes:  12
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 33
  1. #21
    Jul 2015
    Ohio
    740
    Looks like one of mine got sucked through the throttle body hit the top of the valve the valve shot it back up in the head above the valve and made a mark so I'm going to have to pull the head off and see if there is valve damage.... going to do a leak down test first though
    Sounds like i should plan on bringing the viking ...... instead of driving yours
  2. #22
    Quote Originally Posted by jerhomey View Post
    I will know this evening
  3. #23
    Jul 2015
    Ohio
    740
    Ok no biggie either way.
  4. #24
    Daryl O's Avatar
    Oct 2016
    Poteau, Ok
    89
    Quote Originally Posted by rsuch54 View Post
    Thanks for the heads up. I broke off the 2 tabs holding the lid on so I ended up screwing it down lol
    I broke mine to. Went to dealer to buy other one and they replaced under warranty.
    2016 Wolverine
    Eibach purple spring
    Extreme Sheave 16 gram weights
    slugs
    28x14 Roctanes.
    2 in Highlifter
    YXZ seats
  5. Likes rsuch54 liked this post
  6. #25
    Big Dog Daddy's Avatar
    Kentucky
    1,463
    I have read about this issue somewhere but can't remember where. I just serviced my filter and everything was in place.
    2" Super ATV lift
    Pyle audio system
    Yamaha over fenders
    4" cage chop
    27" tusk Terabites
    JBS extreme sheave
    16g OD weights
    Purple Eibach Spring
    Slugs
  7. #26
    Kentucky
    1,463
    2" Super ATV lift
    Pyle audio system
    Yamaha over fenders
    4" cage chop
    27" tusk Terabites
    JBS extreme sheave
    16g OD weights
    Slugs
  8. Likes rsuch54 liked this post
  9. #27
    This thing bugged me and I went back and looked at my filter. Keep in mind I bought my Wolv used with 700 miles and I know it was serviced at least twice and filter is not too dirty now. It had two small self threading screws in the end cover that could not tighten up very well so I replaced them. But they are on the outside of the filter where they should be, no screws on inside of the filter.
    James I have a bore scope and if you want me to send it to you to look inside the motor just let me know. It has been a while since I used it and I will need to check if it will go in our sparkplug hole if you want to look inside the cylinder before pulling it apart.
    Well I jumped in on this earlier without enough investigation. This morning I took my filter apart to replace the element with a NO-Toil. I found the referenced screws. I did have two which appear to be designed to hold perforated screen in place but do not do a very good job. There are actually four holes for this in the plastic cage. I took out the two little screws and found some little self-threading screws in my can that was I believe from some electronic gear. They were like 1/2" by #4 Philips with a washer head that easily covered the edge of the perforated screen and clamped it down. They easily threaded into the plastic cage holes but a little long so I ground off about an 1/8" of length, and they are tight in the hole. if one comes out and I do not believe they will cause of tightness of the fit, if the perf screen stays in place the screws cannot get into the inside airway. I hope this helps someone else.
  10. #28
    Checked mine out today and had a suprize, opened up the cover and i thought what died, then i seen how dirty the filter was inside the box and thought maybe one of those stinky mudholes was the culprit, I pulled the filter out and seen the inside was clean so i pulled it off and both my screws were still in place and tight but im gonna do some mods and make sure theres no future problems.
    When i went to clean the airbox out i found out where the smell was coming from, it was a dead mouse, lol.
ID:	12546Click image for larger version.
ID:	12547Click image for larger version.
ID:	12548Click image for larger version.
  11. Likes WV Hot Rod Rhino, madmax 1 liked this post
  12. #29
    I found the same problem on my Viking.The screws were both loose ready to come out because the cage slips out from under the screw and then theirs no tension on'm,I did the zip tie mod on mine and sinched the crap out of them and closed the gap a lot tighter used the screw holes for zip ties,what a shame it would B to lose a motor over 1 F%$&(#g screw,sometimes i wonder who designs this shit,by the way the Wolvy screws are larger than the Viking.
  13. Likes WV Hot Rod Rhino liked this post
  14. #30
    Rivets look and work the best i think
  15. Likes HillbillyStyle liked this post
Tags for this Thread
