Thanks Thanks:  3
Likes Likes:  17
Results 11 to 15 of 15
    Texas (Victoria area)
    661
    Quote Originally Posted by Shawnh View Post
    Great honest write up --- thanks for sharing. I have had 2 Rangers and they did everything I wanted them to do. Really good machines
    Thanks for reading all my ramblings.
    An honest review is always the best review. Unfortunately, such an honest review is hard to come by these days when so many reviewers suckle the corporate teet. It's either reviewers who won't say anything negative about a product because of a backdoor sponsorship, or it's reviewers with little real world experience trying to talk about a product they've spend minimal time holding. They're essentially saying, "It feels good in the hand." LOL!!!
    I'm not the definitive authority on Polaris Rangers. Mine continues to be fun, but it hasn't been perfect. I can admit that.
  2. Thanks WV Hot Rod Rhino thanked for this post
    Likes WV Hot Rod Rhino liked this post
  3. #12
    661
    Ranger 900 Long Term Update
    The SuperATV RackBoss steering rack was starting to get sloppy. The internal teflon bushing showed wear within 1,000 miles. The majority of those miles were running 27" tires. I replaced the RackBoss with an OEM steering rack. The picture below shows the bushing. Note the lower left section of the bushing how the teeth of the steering rack have worn away bushing.
Name:	Worn Bushing.jpg
    My front AWD gearcase was leaking fluid out of the front pinion seal. While I had my front end disassembled for work to the steering, I pulled the front gearcase for inspection. I found play in the pinion bearing. Removing the gearcase pinion seal revealed (another!) bearing spacer/retainer come loose. I'm not sure what the proper term is for the plastic clip that evenly spaces the ball bearings, but that part was dislodged. The ball bearings were free to move about inside the race causing some loud marbling noises in the driveline. I clipped the retainer back into place and noticed the slop in the bearing tightened up and the marbling noise went away when manually rotating the pinion gear. Nonetheless, I went ahead and replaced the pinion bearing with a new bearing.
    I took the family out for a ride and to give the Ranger a test with the new front end parts. The new steering felt great. I suppose you don't realize how numb the steering is until you install new parts. The Ranger drives and tracks well.
Name:	side view 1.jpg
  4. Likes scottwv liked this post
  5. #13
    NickH's Avatar
    Northern Cambria, Pa
    842
    Chris, are you considering getting rid of those 'polaris clothes' in your sig yet with the new wolverines out there?
    2016 Yamaha Wolverine R-Spec SE. 12" double row LED's from Flimmy, Warn Vantage 3000, SSV works audio system.......I need to add more parts!!!!!
  6. #14
    661
    Quote Originally Posted by NickH View Post
    Yes, I really like the new X2! I am eager to see one in person.
  7. Likes NickH liked this post
  8. #15
    10,107
    they are smaller than most people think. less cabin room than your Ranger and less top speed but less maintenance also
    Quote Originally Posted by Chris View Post
