Trickle charger???
I want to hook up a trickle charger to the battery in my Rhino. I have heard it's a bad idea to charge the battery with a standard charger with it wired into the Rhino because you can blow the digital display. With that in mind can I use a battery maintainer like a battery tender while the battery is installed? I want to run the pigtail out the side so I don't have to raise the rack and hood all the time.
Thanks
2012 Yamaha Rhino... Camo...
Roof with soundbar
52" lightbar
folding windshield
hood rack
4500# winch
Extreme sheave w/ purple spring 19gr OD weights
Slugged clutch
I have a trickle charger hooked to my viking most of winter and no issues.... rang plug end out grill and strap locked it in place
2015 Viking EPS SE
KFI Stealth 4500s
KFI 72" Open Trail Plow
SuperATV Flip Up Windshield
SuperATV Side Mirrors
Seizmik Soft Rear Window
IR Backup Camera
42" LED Light Bar
JBS Extreme Sheave
JBS Slug Kit
Black & Gray YXZ seats
Lots More Planned...
I do and have since the machine was new, have not had any issues. In fact my Rhino is running the original battery from '12. Probably gonna shit the bed now that I've said that, oh well. I have been using Battery tender on mine. Good luck.
'12/700, 26" Bighorns, custom made rockrings welded to stock wheels, 3" Xtreme lift, Warn RT 2500 lb. Winch, Big gun Exo exhaust, UNI filter system, custom self built Molly cage, 5 point RCI harness, Hi-lift utv Jack, HID headlight kit, 4 Anzo HID lights across the top, piaa up front, JBS stage 2 Extreme sheave with 17 gram od. Purple spring And slug kit,Cobra dx lV CB with firestik ll antenna, 2" front wheel spacers and 2 Kolpin 1.5 gallon cans at the rear
I ruined an AGM battery last winter placing it on a regular battery maintainer. The guy at the battery shop showed me a nicer maintainer that was selectable between regular batteries and pulse charging for AGM's. The one I got there is called Genius G1100 from Noco, and it works great.
On my new Kodiak I wanted to easily charge it so I rewired the power port to be connected to the battery instead of ignition. I went down and bought the car port accessory GC003 for the charger, and now I just plug it in when it's stored.
https://www.battsys.com/noco-g1100-6...iABEgJD2vD_BwE
https://www.cpooutlets.com/noco-gc00...iABEgLM5fD_BwE
Have used a maintainer on both Rhinos for years in the cold azz state of Wyoming and no problems with the digitals and always have a strong charge on the batteries. The '06 OME battery stayed good until just a few years ago.
06/450: Rhino;
JBS Hot Rod Sheave/12gr OD's; Blue Spring; 04 Style/KN Air; Dyna CDI; Axia Exhaust Tip; 3" Lift; Sport Shocks; 27X14 Mudlite XTR's; Warn 2500#
08/700: Rhino;
JBS Hot Rod X-Sheave/16gr OD's/Slugged; Purple Spring; Alba TB; Raptor HotCam; MSD/JBS-Map; Yoshimura Duals; Pro One Doors; LSR MTS; LSR Front & Back Supports; Ricochet Skids; Elka 4's; RackZilla/PS: 26X12 Pitbull Growlers; Camoplast T4S; Viper 4500#;
Trail Bright LEDs.
I ruined a good AGMs last winter with a cheap maintainer as well. Since then I have noticed that the Battery Tender gets some good reviews on the forums. This winter I have wired in a pigtail and hook up the charger/maintainer once a month for overnight. Batteries are doing great that way. I have one AGM and OEM with a switch that I can maintain individually. I have my Wolv in a semi-heated garage, if I was in an unheated barn that got very cold, I would do more to make sure the battery was at peak in severe cold spells.
