Thanks Thanks:  7
Likes Likes:  21
Results 11 to 13 of 13
    10,102
    mine overheated so bad it blew the reservoir cap off before I got the mud guards
    it's the best mod ever...well, that and the JBS clutch, JBS springs, JBS cage.....
    Rhino SE 66's Avatar
    Jan 2014
    Lafayette Indiana
    118
    James, are you still making them for the Rhino? i need to get a set.
  3. #13
    txgrown1404's Avatar
    wichita falls, tx
    1,923
    Quote Originally Posted by Rhino SE 66 View Post
    Yes he does
