Ryan's front drive shaft with 35s and portals is starting to slip so we cut one apart to see how it worked and came up with a fix now we're going to test it.
I like the pin vs welding it. That way you still have a weak link that is cheap. And, if it needs a little more, you could maybe throw another in there beside it.
Kind of like a shear pin on a boat prop? Sounds like a good idea over welding.
2015 Viking EPS SE
KFI Stealth 4500s
KFI 72" Open Trail Plow
SuperATV Flip Up Windshield
SuperATV Side Mirrors
Seizmik Soft Rear Window
IR Backup Camera
42" LED Light Bar
JBS Extreme Sheave
JBS Slug Kit
Black & Gray YXZ seats
Lots More Planned...
So what keeps the two halves from spinning in the sleeve to start with?
2017 Yamaha Viking EPS
2" lift
28X9.50X12 Outlaws
I think it's a press fit, so it only slips if it's under a real bad load. My guess is after a few times it gets wore down and it's done.
The idea of a shear pin is rational but the implementation may be a challenge to find the correct values if you want it to be the weak link. The shear pins I have seen are on a low HP motor and are brass or a weaker material that is designed to be a quick failure to save a shaft and maybe the prop. If you're willing to risk the diff then use a solid pin. But the torque of a 50 HP/1400 lb machine seems challenging to find a fine line between max application vs saving diff gear teeth or CVs.
Any updates on this
