Likes Likes:  1
Results 1 to 6 of 6
    Janesville, Wisconsin
    316
    Water In Front Differential
    Apparently I got water in my front differential somehow. I don't ride in the water/mud very often, but when I do, it isn't very deep (center of wheels).
    This was discovered when I drained my differentials to do a fluid change, and I suspect that I am going to have to do another drain after I run it around a little to mix everything up again.
    So the question is, how did the water get in there? I do pressure wash my machine regularly.
    Thanks.
    Check and make sure the vent hose didn’t get knocked off differential.
    Vent tubes aren't long enough and it lets water get in them.. I got videos on this for the Wolverine...
  4. Likes Timmi liked this post
    I need to do mine
    I have not been into the Wolv front diff but I trust it is similar to the Rhino. In addition to the axle seals, there is a seal at the actuator motor base that is not too hard to replace once you get access. IIRC on Rhino it is an O-ring. Typically they need a little lube and patience to make sure they don't roll, pinch or split putting it together. Could be Bubba in Georgia had a relaxed Friday afternoon lol.
    scottwv's Avatar
    Charleston , WV
    2,193
    I had to put all new bearings in my rear diff because of water. A bad cir-clip was the culprit .
